Cranking Problem
LSXGUY
I have a 2004 Tahoe Z71 with 222k miles. When I got it the only thing that had been changed was the water pump. I had to do a power steering pump and I did plugs/wires, K&N air filter, oil/filter, and fuel filter, and I had it tuned with HPtuners.
The problem im having is its hard to crank when the motor is cold. If you prime the fuel pump a couple of times it will crank right up, but still kinda idles rough until its semi warm. So I had a hunch that the check valve was bad in the pump and checked the fuel pressure with a gauge, If you turn it over once it comes right up to 48 psi, then if you crank it, it stays 48psi. I know thats about 10 psi to low but I figured if it was loosing prime it would be low the very first prime. While data logging with HPtuners, it seemed there was unmetered air like a vaccum leak or something. So I was thinking maybe intake gasket. I sprayed some seafoam all around the intake and couldnt find a leak. Also was getting some codes for running lean....any ideas?
thaze12
I must admit before I say anything, that I'm not too knowledgable mechanically. I've had the lean code on my truck as well. For me it was one of my fuel injectors. Hope it helps, if not srry. lol
nuc_meltdown
NW Alabama
Did you check the fuel pressure regulator? Not sure about yours, but on my 2000 5.3 it's on the driver's side fuel rail. It has a vacuum hose that runs to it. Pull that hose off. If gas comes out then the FPR is bad. If not then I would lean toward the pump. Something to check anyway.
08DenaliMan
