Crankshaft Position Senor Question...
SeriousSide97
guys Im doing a few fall tune up things on the hoe. Now I want to replace the crankshaft position sensor but If I do, will I have to relearn the cps when Im done. Im not throwing a code or anything but I believe the one Im using is orginial and might have a worn gasket on it. any help would be well appreciated.
S
SeriousSide97
really? whys that ? how much do you think a dealer will charge me to relearn it?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
There are always small variances during manufacturing that at rpms can be a tad bit different then the last one. The computer needs to perform the test so it can distinguish was it is seeing with the new sensor. If it is not done and you misfire is may give false readings on what cylinder is misfiring among other things. It is a 10 minute procedure really and you should not get charge more the 30 min of labor. Might even get it done for free.
S
SeriousSide97
cool thanks. hey if i just take the old one out to inspect it would I have to relearn?
S
SeriousSide97
ok thanks. I might go have my cats done today. well see but Im hoping to get this issue resolved asap. I wanna rebuild the front end before winter hits.
