Crap....
Fishin757
VA Beach
decided to take a look under the rear end of the hoe today and noticed that my lift blocks have moved about an inch forward. i thought no big deal i just did t torque it enough, I'll get it tomorrow.. so i thought... took a closer look at it just a few mins ago and its not the block that moved, its the axle that slipped back. soooo needless to say im a little hesitant to drive it with only an inch or two before my driveshaft comes free. im going to drop everything tomorrow and slide it forward and torque the heck out of the u bolts but thats just a bandaid on an open wound. im thinking i need to get some shims and put them in the back of the block to keep it from sliding and raise the pinion angle up slightly to the shaft is straighter. any thoughts?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Did the blocks not have holes, pins or some alignment point to keep them from slipping out of position? And only reset your pinion angle in the rear half of the drive shaft so it matches the front half of the shaft in degrees. Do not set the front, for example, say at 7° and the rear at say like 3°. Must be an equal amount.
Donnie Yukonie
Yates Caretaker
This ^^
All Blocks should have a centering Pin milled into it that slips into the Axle arches to prevent this , Take them off and inspect them to make sure they are not broken or missing !
Fishin757
Fishin757
VA Beach
they were there when i installed the blocks but im feeling like they must have broken out. theres no way the hole hopped over the pin. ill try to get some pics up when the rain stops, if you havent been to virginia beach in the summer just imagine 90 deg 90% humidity and it raining every other day
---------- Post added at 02:44 PM ---------- Previous post was at 02:42 PM ----------
thats why im thinking shims
SunlitComet
OBS Jedi-Do Good
dude I had to work in west virgina on a crj-200 with that weather and when it got cold at night it got so bad and foggy I could not see my tools 5 feet away from me. Glasses dripping so constanly fighting to see what I was doing. Crazy ****.
Fishin757
Fishin757
VA Beach
yeah man its like that down here. its mid afternoon and there is a humid haze already. all i can say is i love the walk in freezer after a day of fishing.. always kept at a frosty -5 deg
_Dylan_
STAY FROSTY
maybe those stupid blocks snapped off the centering pins on the leaf packs
Donnie Yukonie
Yates Caretaker
To be honest I doubt any of this , I have had my truck off road quite a bit even on some harsh trails at RC and I have yet to break one ,
AMM1986
