Crappy Stock Brakes-need upgrades
sparg93
Expedition Tahoe
NJ
thoughts on upgrading the master cylinder? i read in article it can help with the sloppy feeling...but haven't found any other write-ups.
thoughts?
bowtiefreak
No Quarter
Near Philly
Like everyone has said:
Hawk pads
Powerslot rotors
SS lines
new fluid
A new masrer cylinder would not hurt...but not a stock unit. There are some write ups out there on putting a NBS master into the OBS trucks. The NBS has a larger bore allowing more pressure so I am told. SSBC sells what they call a firm feel master cylinder, it is not cheap. Again, I can not back any of this up about the new master cylinder.
haks310
Got LEDs?
SoCal
Hawk pads
Powerslot rotors
SS lines
new fluid
No, you are right about the NBS master cylinder, it needs is a fitting to make it work. And the cylinder SSBC sells....it's a NBS cylinder.
sparg93
Expedition Tahoe
NJ
Which Hawk pads did you end up going with? I've read the writeups on there multiple versions, but I really didn't see a big difference (except for their $110 ones).
PowerSlot also makes slotted + drilled...ever heard positive/negative about adding the drilled versions? With my driving, i can't imagine i'll ever heat them up to the pt that having drilled would prove beneficial...but i'm always open to recommendations!
haks310
Got LEDs?
SoCal
LTS
No need for drilled. I'd be scared of the possible cracking that might happen around the drilled holes also.
Rudder
Maybe its my motor mounts but whenever I accelerate from a stop I feel a 'clicking' if that makes sense.... Would this be attributed to the brakes also or could it be the motor mounts.
Hey Sid,
I just got a 99 Tahoe and I have the same problem that you stated here....any ideas of what it is?
Cheers
sparg93
Expedition Tahoe
NJ
LTS
Agreed - for my application i couldn't think of the potential benefit outweighing the con.
Thank you for all your help Haks, after i finish up my recent project (poly bushing on the sway bars) brakes will be the next item on the list!!
eZg
Hey Sid,
Cheers
I have the same issue. I also notice it under braking.....anyone got a clue?
Thanks
REGolfPro
