Woodblocker55
- Joined
- Apr 13, 2019
- Posts
- 668
- Reaction score
- 421
You were right on the money [emoji106] thanks for the post . Switched battery out and it's fine .with the u0107 that rules out the failure of the throttle system
it just says you lost power to the TAC module
the other codes were a domino effect because you lost communications to the TAC
put the key to the run position for 4 seconds then start it
if it starts fine then you have an issue with the battery or charging system (including the ground wires and or wires to the control module )
Sent from my LGL84VL using Tapatalk
