Creaking above passenger side second row bucket
Bigmanny
I tried to put some foam up there and I am not sure if that fixed anything. Anybody notice that the crackling is worse when the panoramic shade is open?
J
jjobev
I will listen to see if I notice a difference. For the foam I found I had to put foam that was thick and barely fit when being pushed in. The first couple of times I tried I didn’t notice a difference and don’t think my foam was big enough to stop the sound. Mine was primarily on rear passenger side and that seems to have gone away. I did notice above my head when driving the other day a couple of times so added foam there. I’ve got car seats installed now so I get a lot of noise that that stuff too.
B520044
I think its worse only because the sounds reflect more off the glass.
Bigmanny
Anybody bring this up to dealer / get a response? Any TSB yet? It is now all that I notice while driving.
I was without my truck for 30 of the 90 days(safety restraint, Exhaust issue/muffler replacement, 3rd row Headrest issue, brake reprogram recall) that I have owned it. I have issue fatigue at the moment.
jna97
Houston Texas
You guys see if the below makes sense to you........
Yesterday I did some more testing and found some interesting results. The white clips are two pieces. The top part of the clip actually is installed in a track around the pano and is the female part of the clip. You can slide it back and fourth along the track the entire length of the pano. The bottom part of the clip is the male end and snaps into the headliner trim in certain places. There are 4 clips on each side of the pano. The clips are extremely fragile and break very easily. The part of the clip that breaks is actually up in the pan frame track. You will notice a clip is broken when the top part of the clip will no longer stay in the upper pano frame. While trying to reposition my foam I broke 2 of the 4 clips. I popped out the middle two clips that were broken and used some foam (1/4" thick) on each side of where they "would be". This morning there was no noise on my 30 mi commute to work. It seems like the more you reposition your foam, the more the noises move around. Again, it seems like the white clips and how they fasten in the pano frame are the culprit. My next test will be removing all 4 clips on either side and see how that works. They don't seem to really be doing too much. I might even consider adding some velcro.
Very annoying.......
jna97
Houston Texas
It is 100% the clips. On the way home heard the noise again. Removed the 3 clips twards the front on both sides. Zero noise.
B520044
Great information! Thank you for digging into this further! This is so annoying to me and I already have another service appointment next week. I was going to remove all my foam so the technician can hear the noise. It seems to get worse when temps drop. I've reported this at my last two service appointments, but they say could not duplicate.
J
jjobev
Great information! Thank you for digging into this further! This is so annoying to me and I already have another service appointment next week. I was going to remove all my foam so the technician can hear the noise. I've reported this at my last two service appointments, but they say could not duplicate.
I’ve got about 2 hours in vehicle Sunday without anyone else so will see if I hear with the foam I have up there currently.
J
jjobev
And I think if I took the foam out I could replicate the sound within a matter of minutes...but would probably the one and only time It didn’t make the sound.
B520044
What if we put felt tape in between the male and female clips? I can't tell if the noise generates from friction between the clips or from the female(top) clip and aluminum pano frame? Or both.
BurbyRST
