Cruise control not working
woody367
The cruise control in my 99 Yukon does not work. The fuse is good and the brake light switch seems to be working fine with all lights good. Can anyone help figurenthis out before taking a trip in a few weeks. Thanks.
Ponchonutty
New Washington, Ohio
More than likely the brake switch itself is bad. Common problem. Weird thing is the brakelights will still work fine though.
98blackbell
FL
Mine quite and I went thru new brake switch, rear 3rd light replacement. Ended up being the control module on the firewall. I went to pick and pay took one for $23 and plugged it in. It worked?
woody367
woody367
I fixed it. It came up with a code for low voltage brake light switch. What a pain tp get to it to change, no room. It works fine now. The brake lights always worked fine.Thanks
jgrundy13
