Cruise control stopped working
ILLEGAL REGAL
Tinley Park, IL
mine no workie neither, recon led tails- blink normal speed, shaved 3rd brake light. Not sure where to even start looking for a cure
HELLAbeefy
south louisana
Bringing back the dead horse trying to fix this...
Led tail lights= cc worked
Trans lost R 2nd & 4th= cc worked
3 months after trans lost gears= cc no work
Trans fixed= cc no work
Checked fuses= cc no work
Changed brake switch= cc no work
Cc just stopped working on me. Since it went out the cc light on the dash hasnt come on.
Is the cc light supposed to light up when in park or in drive not moving?
dljepsen
ok so i just recently had an issue with my CC went through everything above on my 04 Tahoe.
checked all my fuses - all good
checked for working brake lights - all good
checked brake switch - obviously good
probed TACM for good signals from the cc switches and brake - good signals.
everything i checked was good. i had my buddy hook up a tec 2 for me at his work and he pulled a DTC p1574. this code does not throw a check engine light on the dash and only can be pulled up by a tec 2.
that specific code says there is an error in the stop lamp switch circuit. so i went back and checked the signals at the TACM and found that the brake circuit showed a .2 volt reading w/o the brakes being depressed. which i guess is just enough voltage to keep the CC from fully engaging.
i then out of a hunch pulled off my trailer light adapter plug. dried it off and somehow water must have got in the circuit just enough to complete a low voltage circuit.
after all of that it started to work.
HELLAbeefy
south louisana
So how did you fix this? [
QUOTE=dljepsen;744135]ok so i just recently had an issue with my CC went through everything above on my 04 Tahoe.
after all of that it started to work.[/QUOTE]
dljepsen
Idk if I really fixed anything but the only thing I could think of is that on the trailer light plug, water got in there and started to complete a circuit in the system causing the .2 volts to go through. Once I dried that plug off (unplugging it from the rest of the harness and letting it dry in my garage) it started to work.
Sent from my DROID RAZR HD using Tapatalk
---------- Post added at 05:31 AM ---------- Previous post was at 05:30 AM ----------
Also once it dried off, there was no more voltage going through.
David Dowling
i had issue with cruise not working on my 2004 tahoe lt I had changed to 22 wheel and did not mount TPS sensors found out when Iloaded my factory wheel in the back to move my cruise would work because it recognized TPS sensors in my factory wheel as soon as I unloaded them and drove off cruise no longer worked
MacG
