Make sure you inventory everything when you get it. I received everything, but I still had to call customer support to check a few things because the pic on their site isn't accurate. I believe it is the old kit, and some of the part numbers have changed but they didn't update the instructions. It also says to remove the torsion bar mounts that are riveted and you will reuse them, but mine are welded to the frame not riveted and from the looks of the drop brackets as well as the instructions a few lines down, I think they stay in place and the bracket actually utilizes them where they are. I'll keep you posted.
