Custom box I had built for the Yukon!!!!
Phantom240
Needs an aero/flared port, but otherwise, excellent work. Must have take forever to kerf that plywood. Also, is that an SA or an SD?
jmax313
jmax313
Its a sa but he said I can switch to a SD... Far as the port I'm lost on that
Sent from my SPH-L710 using Tapatalk 2
EMF Audio
Spartanburg, SC
I kinda wonder on that port. It's not smooth on the inside and not real solid. I think going another route might sound better, even if it sounds good now.
Phantom240
LOL
That's one way to do it, I suppose. That port is DEFINITELY sketchy as f*ck.
An aero port is a port where both ends have a parabolic flare. It helps reduce noise and increases volume a slight amount.
Administrator
...and didn't you say you had a shop build you that box? Are they an audio shop or ?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
yeah that port isn't really doing much but moving around inside the box. If I were you I'd take some of the same size PVC pipe and make it look identical to the other stuff...
swazzie
