Matthew Jeschke
Pretty well have it wired up. I called my buddy who built the HD C/K series stuff. He retired from GM truck factory in Michigan. I wanted to run the wires with bundle as factory would have. He said the main wiring bundle for the dash is located directly above the steering column and said if I drop the column out I'd have direct access to it. He also said there's a strong possibility the factory would have left the connector and everything there to plug into the button. I guess standard practice was to use the same harness for everything... Then just not connect options if they were not installed. Long story short I didn't drop the column but I used fishing line to pull the wires along that route.
I've almost got it all wired in. I'm only lacking dash illumination for the button. I need to find where it's easiest to tap into that at. I was tinkering with the light switch but couldn't tell which wires are for dash illumination.
