TPMS and Torque app
TJ Baker
Anyone know how to get the gear selection to work? I used to have it on my old phone but cannot get it working on the new one. This is for GMT900.
I am fairly well versed in the older pre-CAN system(s). Don't know doodley-squat about CANBUS.
I don't believe the "01" I add to PIDs applies to CANBUS ISO 15765-4 vehicles.
But maybe GM uses the same PID ## for both?
With the older Class 2 serial bus J1850VPW vehicles the common PID is 199A. So in apps like Torque Pro where we enter mode and PID together it would be 22199A.
But here also it might be necessary to add 01 after the mode and PID. (Torque Pro might add this for you in the background but it is faster to just do it yourself)
Other apps like OBD Fusion keep mode and PID separate. So there you could add "01" after the PID if you find it is needed to get the PID to work.
Example: Using a terminal app here I asked for 199A by itself and the PCM replies with a 7F response. I added the 01 at the end and got the reply I need. ( the "02" near the end means "reverse" )
TJ Baker
And here is another twist.... If your IPC uses the Class 2 J1850VPW bus, in Torque Pro you can ask for the data without even using a "true PID" in the usual sense. It is possible to use Class 2 communications as defined in SAE J2178. So there you can likely get the "range position" that is sent from the PCM to the "PRND321" display of the IPC.
a9lyphe
