Custom CB Install - 07 Tahoe - Bearcat 980 SSB
Livewire18
So, a little background first. My Tahoe is a 2007 Z71 LT3. Pretty much every option offered except the power folding rear seats and 20in rims. It is pewter with the two tone (black/grey) leather with quad seating, sun roof, nav, etc....
Since I got the hoe' I have been looking to add a cb since I had one in my last truck. However, for any of you that have the full console, this can be quite a challenge trying to find space.
Here is what I installed:
Uniden Bearcat 980 SSB
9ft of RG 8X coax
Firestik K4 - mount
Firestik K1-A - quick disconnect
Firestik FL3-B - 3ft firefly antenna
I was toying with the idea of mount it in the center console, but decided I wanted it more accessible, so I decided to cut up the center console (yes... I broke my heart, for a minute).
After spending about an hour taking the center console apart and removing it from the Tahoe, I separated it into a few pieces and started trimming the inside frame to allow the CB to fit all the way down as far as I needed it to be.
Once the frame was trimmed, then it was on to the "visible" portion of hacking... there was no turning back now (unless I buy a new tray and cup holder).
Once I cut the hole for the CB to pass through, then I shaved down the retaining tabs for the cub holder and change holder so that I could move the cup holders forward.
Then I screwed through the side of the tray and into the cup holders to attach them in place.
Next (after routing the cable through the firewall and spending 2 hours on the mount, which I have to still get pics of). I put the console back together and started mounting everything up.
Then after a bit of final trimming, I got everything back together.
Well, it looked ok, but I wasnt happy. So I spent about 5 hours with a piece of 3/8 alluminum fabbing up a faceplate, and then spend 4 hours driving around trying to find something that will match the dash trim (still havent yet, but have some samples coming from a place online to try). I did find something close though, but still not 100% happy with the match).
Sorry for the crappy pics, it was late when I finished, but I will get more of the antenna, mount, and day-time shots of the finished project.
Also, for the future I am looking at getting a 2FT Firestik for daily driving, and keep the 3ft for travelling and trails. Yes, I said trails, this will not be a mall crawler.
As of right now, everything between channel 9 and 40 is sitting at almost perfect 1.0:1 SWR and below 9 is right about 1.3 SWR.
Pictures of the antenna and better pic of CB is further down thread.
SPLmonster13
Texas
So clean! I want to do something cool with the CB iny OBS tahoe. Great job man!
NathanJax
Vacation Nathan
Administrator
Jax, Fl
That looks great!
Livewire18
Livewire18
Thanks. It's not as clean as I would like it, but it will work for now. (thats my OCD/perfectionist side coming out).
Also, I have been trolling the board lately today, and I am thinking I might even do a plastic dip on it so it matches the rest of the console instead of having it brushed nickel.. Not sure yet though.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I would. I'd also do the top part of the console lid as well.
Livewire18
Livewire18
I will get pics of the antenna later today, but it is near the driver's side hood hinge. I found a company online that made a kit, but they wanted over $80 for it. So, I fabbed one up myself. It was quite easy since there is already a mounting plate under the hood cover, all I had to do was open the hole bigger and then drill a hole in hinge cover.
Livewire18
Livewire18
Here are some better pics of the CB and also of the antenna/mount.
With antenna attached
with antenna removed (firestik quick detach)
mount
TwiztidFate
