Cutting :(
TEXAS DEMON
with a vengeance
texas
in the front fenders at the very bottom, there is a seam that joins the fender. against the firewall, you will need to flaten it with a hammer or go to bodyshop. but that is where the problem is.
NASTY GM
Nor Cal
If your going to bag it I'm not sure I would use that hit. It cost a lot and it doesn't get it low enough.
jtalambo
I can't see that ever being aligned since the bags never has a constant height.
syndicatesteve
Syndicate Steve
Southern California
it has to be the offset of the wheels. I am completly bagged to the point that my inner fenders sit on the top of the tires, and I still don't rub. Even when I had the McGaughy's 4/5 drop kit I didnt rub, but then again I am running 255/30/26 tires.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
on the 24s i do on the nnbs with djm 3/4 kit (not tb springs) ive donet 24x9.5 38mm offset with 295 35 24 and its been fine.
Jellis02
