Cv axle or front differential
OR VietVet
Multnomah Falls
Military
Willamette Valley
Yep, either inside that axle housing, no/low fluid damage?, or that is the strangest sounding wheel bearing I have heard. What does it do when driving straight down the road? Slight turn to the right that would load the driver's side wheel bearing?
S
Sean Patt
It drives perfect, I can only hear a slight tapping sound when I drive 5mph or less. I noticed the noise when my wife was pulling into the driveway about a week ago. I jacked up the front end and spun the tires by hand and noticed a slight sound on the driver side. Then pulled the tire off and made that video. I had the front differential serviced/fluids changed about 10k miles ago.
ivin74
05 NBS Nali
Htown, Texas
Disconnect the axle and test again, sounds like the gears to me. The adjusters n.u.t.s might have gotten loose inside the diff. It's a common issue with gm 8.25 IFS diffs.
BurbyRST
