CV shaft
R
rojerio
chicago
yes i have taking it to mechanics and they tell me they cant find the play in the front end , i have replaced the EVO sensor steering position sensor , Intermediate Steering Shaft , gearbox , idler arm , Pittman arm , all ball joints , stabilizer bar rubber , upper and lower control arms bushings it used to be very bad a lot of play but i tighten the idler arm as much as i could and that took most of the play away like 90 percent the play is like an inch of play im tired of this truck im scared to drive it ill just have to keep trying thanks for replying i appreciated
OR VietVet
Multnomah Falls
Military
Willamette Valley
A "qualified" tech should be able to find whatever play in the front end there is. If the same mechanic has been replacing the CV shafts, 6 of them, I would find another tech(s) to go to.
OR VietVet
Multnomah Falls
Military
Willamette Valley
I have never recommended a dealer tech unless it is a covered item under a warranty. There are qualified techs out there. Hell, I know I could find it if given a chance. I used to specialize in this type of diagnosis after some training from a very smart shop owner I worked for years ago. Steering, suspension and brakes were his bread and butter and he taught me more than I already thought I knew. Did you find your current tech by word of mouth thru friends? Try it again or post where you are, in Chicago, and someone here, close to you, may be able to recommend a shop.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Ok, so now hopefully a member or two here will chime in with some recommendations. Give it a little time.
exp500
Sounds like it needs a very close look at everything under the front. Look for accident damage, curb damage, front axle seals leaking points to a vibrating axle meaning bad wheel bearing or cv joints. Loose steering gear- have someone hold the shaft and gently turn steering wheel left and right a little to feel where the play stops. If no play in shaft then its steering gear if steering wheel moves and wheels don't. Jack up wheel and spin it by hand. then do the 3/9- 12/6 wobble shake test, while someone else looks at ball joints /tie rods/ idlers/ pittman for movement/play. Good luck.
GuillermoDelTahoe
