BOAT Load of codes!
Tangojay
This mess started with a “stabilitrak” warning plus “parking assist “ disabled, I tried unhooking battery ( only negative) and all was well,, until a couple of days ago, they came back, plus the cruise control does not work. I bought a new code reader (the one I had was bought around 2012) and it gives me 33 codes! Here are some codes,,,
LordWayback
I’m pretty sure GM had a recall on a ground for a similar situation
LordWayback
Look up G218 Ground fix if it doesn’t apply to your models or years you might have something expensive going on I know atleast 2014-2018 has issues with (stabilitrack) or masses of codes that can be directly related to that ground
As @Doubeleive stated above, whenever you get a sudden slew of codes popping up, it is generally related to your electrical system. More specifically, (1) your battery may be failing, (2) your battery cables may be failing (they rot from the inside out), or (3) bad or broken ground strap or frame connection.
Check out these 3 sources of this issue, and more often than not, you will find the root cause in one or more of these 3 areas.
HAIGDEDNEDNA912
