Dash Replaced
justchecking
Military
SW Ohio
Thanks for the link!
What's the issue with power to them being on all the time? Do they have a high passive draw?
I use those. That little button on the right turns them on and off. I have left them on before while the cars have sat for a few days with no problem. The passive draw does not seem to be too much.
Edit: So I had one in the shop and measured it. Off current is 2mA. On current with no load is 8mA. On current with load is dependent on what you have hooked to it of course. .
j91z28d1
I purchased these on Amazon. The fitment for the lighter was a bit smaller than the USB adapter, so I had to Dremel it a bit to open it up. I also put one in the back seat for the rear passengers. I still have a lighter in the center console and the back if I need one. This is the exact one I used. It's a simple hook up. The only thing I hate is the aux fuse is a constant 12v. I am thinking of rewiring them to a proper ACC that turns off when I cut the engine.
if you can find the retained power wire at the radio somewhere. that might nice to use instead of a hard cut with the key acc. I have mine wired to acc and use it for the Bluetooth dongle so it doesn't kill the battery but it would be nice if it stayed in with the radio till you open the door or it times out.
mikez71
I believe the radio only has batt power, and relies on gmlan to turn the radio off(and on!!! despite the power button on the radio, I believe if you just wired power to the radio, it won't work!!).
The MBEC has a plug terminal that has retained accessory power, but at 300mA, you probably need to wire a relay to power anything reasonable).
Also a 10A run/crank feed, which may not be enough for 3 adapters fully loaded...
I purchased from this exact seller since he has a better listing with the info u need
funny I wish the radio would go out with key off, cuz if I wanted the radio on, I would just leave key in?
I do really like extended accessory power (autosync programming feature).
With that I can key out, open doors, and still row my windows down. (for upto 250 seconds maximum after the door opens.)
Also can hit remote unlock and there will be accessory power..don't need to insert key..
(can remote power windows for that matter, but only full open or full closed..)
Enrique01
