Dashboard
andydallas
Does anyone have a link or pdf of instructions to remove the dashboard for a 2007 yukon? Its cracked and I need to replace it. Thanks in advance
A
andydallas
um ok
so that didn't work...
anyone know how to get the passenger side airbag out?
i got the dashboard covered, still need to get that airbag out..
anyone....
fiatdale
Houstons Best
Houston
You need to take off the passenger side woodgrain trim. Be careful as its fragile. Once removed you will see holes for access of two 10mm bolts that hold in the airbag. (There may be 4 bolts. I havent done one in a few months) Drop the glovebox all the way, unplug the yellow connector (it has an orange safety pin that must be pulled out). Also, you'll have to pull the plug off of the support thats there too. Once all that is done, push up on the airbag itself from under the glovebox and it will pop right out. just be careful of the metal bracket on the airbag when putting it back in - dont want to scratch that new dash!
A
andydallas
Thank you! It was actually 4 bolts...
so now $350 and 3 hrs later I am good as new!
dylanrog24
