Daytime running lights
Phil S.
Phil S.
Wheaton Illinois
So I had one of the DDM ballasts go bad in the first few days and at the same time it popped the fuse for the DRL. Ballast is replaced and I am thinking of just leaving the fuse out. Is there any negative side effects to this?
Johnny Racer
Chicago, IL
There is a way to get bulbs in the upper corners on these trucks? Oh I gotta see this cause its always bugged the piss outta me that they are just reflectors. Where can I find more info on this mod???
blinger069
Vancouver BC
Yes Please
Heya Phil s, is this complete yet ? I would love to see it finished , also would like to relocate my DRL to from headlights to park lights too.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
that might be a little to much for drl relay and fuse to handle. used a fused relay that is triggered by the drl relay or headlight wiring that will power the parking light circuit.
btw :welcome:
LI99HOE
Top Notch Tech.
N.Y.
No fog lights on truck = pull DRL fuse.... no neg effects.
Fog lights on truck = Disconnect wire plug to DRL diode.... no neg. effects.
(DRL diode is under dash, just above gas pedal...has heatsink w/fins on it)
canjo
