Dead battery, I'm done with Optima!
moviewithnotitle
moviewithnotitle
Jersey
With the second battery install, did you run an isolator, or just run them in parallel?
Do you think that replacing the 8ga feed to the fuse panel with a 4ga feed made a difference?
Just an Isolator. I don't venture far off the beaten path anymore to warrant any higher accountability on the system.
I think I would recommend to EVERYONE that they upgrade the feed to the fuse panel under the hood. It's only a 8Ga wire directly from the battery. I found the mount at the fuse panel to be a bit loose, although I have never touched it. It also has some very minor wire corrosion creep at the fuse panel connector. I noticed that my blower motor does work a little better and that interior lights seem brighter as well. This was just off the single battery when I tested it during the work.
My truck was built in 1995, I can't help but think that some of the OEM is getting old and worn out, even though some of the wire still looks good (looks are deceiving).
retorq
Kingman AZ
I just fixed a friends 2002 Ford Taurus cables, they were rotten on the inside, green dust all up and down the cable even thought the ends looked good. :emotions122:
sparg93
Expedition Tahoe
NJ
i just read a number of reviews on the Optima Yellow Tops and they tend to last <2yrs!
I'm also looking into new batteries...why do you guys prefer MTP-78 to other batteries?
---------- Post added at 12:19 PM ---------- Previous post was at 11:56 AM ----------
This might be a REALLY dumb question...so please bear with me.
The MTP-78DT is a 12volt battery. My Tahoe indicates 14volts...why the difference?
moviewithnotitle
moviewithnotitle
Jersey
I liked the specs on the MTP-78's. Higher CCA, good reserve etc. The warranty is also a big plus. Interstate does well backing their products too. Price is a good consideration too. My MTP's were $107/each. I got both new batteries for just a little more than the price of a single Optima.
Regarding the Volt issue, Retorq nailed it.
sparg93
Expedition Tahoe
NJ
I paid a little more, but I'm picking up a new MTP-78DT tomorrow...i needed the one with the dual terminals b/c of my accessories.
I was thinking of running a dual battery setup, but I'm not sure if I need it...
1500w Amp powering x2 subs, 35w/55w HIDs, 135w offroad lights. I may install another 1000w amp in the future, but not right now.
Any need for a dual battery setup? Most of my driving is on the highway so it's rare I have all my lights on and I never crank the system near the limit.
---------- Post added at 12:52 PM ---------- Previous post was at 12:51 PM ----------
forgot to mention - thank you for the info above!
The interior gauge vs battery certainly makes sense!!
oakrdrs187
Coachella,CA
I was told from a battery salesman, that the deep cycles need to be abused and pushed hard for them to lasr. Otherwise its like a laptop thats always pluuged in. Which kind of makes sense, maybe if you had big audio equipment it will lasr longer, im sure the wife will understand.
Torrance1978
