Death wobble
mooman
Saint Paul
have you taken it in for an alignment? Post before and after results. Death wobble can be caused by improper caster setting. Tie rod ends should have ZERO play.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Yes front right tire outside tread wore off
Check that wheel bearing. Right front. Also check the wheel lug nuts.
If only the right front tire is being worn that;s where I would look first. Loose steering parts usually split the difference if one side wears (tie rod) and wear both sides as it re-centers and throws your steering wheel off center.
Fredrikswe
