Debadging
sick1166
fishing line
USE the 3m eraser wheel saves a lot of time and cramps
used go gone and others a lot of scrubbing and scraping not fast or easy as the say the whell took me 5 min for one side
ccapehartusarmyINF.(ret)
Gilbert AZ
no rain ex technically if you doit right you dont even need goo gone just a heat gun and mechanix gloves because you need to head up the moldings more then people think
the way you can obviously tell your not heating the moldings up enough is your leaving behind tomuch adheseive stop and go to the other end start again and apply more heat and almost all of the adhesive should go with the molding use a plastic puddy nife to start it a good way to tell your getting it hot enought is the molding feels like its pretty hot in yer gloves not to hot to handle but pretty hot
HUMBL57
AC Guru
Phoenix, AZ
Just noticed that the last 'E' in Escalade on my drivers door is broken from the top and kind of dangling, looks like the whole thing might be coming off Saturday. Where's a good place to get a 3M eraser wheel on short notice?
Chaz8Mealer
Chaz8Mealer
They may have them at your local autozone. They're at mine so I'm assuming there's a possibility.
HUMBL57
AC Guru
Phoenix, AZ
Thanks for the heads up I will check it out. Only got as far as the flex fuel badge today. BBQ time came fast
Jillb
