Denali Cluster with Heads Up Display
smittyrx
I have a 2015 Yukon Denali without the hud and am interested in adding it. Do I have to buy another cluster and have it programmed to the specific hud? Or is that only for adding the hud and cluster to trucks? I would imagine there would still need to be programming done for the hud to work with my cluster.
C
cmatt
You won’t need to buy another cluster. It’s my understanding you will need the Denali cluster programmed to have the HUD feature enabled in it. You don’t have to program the HUD unit itself.
GMJay
Have you had any luck? I'm trying to do the same thing to my 2016 Yukon Denali. I have all the parts except for the connection from my cluster is different than the OEM HUD projector because mine came with the front collision alert.
C
cmatt
You won’t use that connector with the HUD. It will take a custom harness. @pgamboa can make them. You’ll also need a usb cable. I can give you the part number if needed.
jpcortese
Naperville IL
The cluster and the HUD are two different mods/parts. The cluster has to be programmed for your truck and for the HUD to work.
The center of the Denali instrument cluster is an 8" screen. You can choose between 3 different "modes".
This thread is more detailed and has way mpre info http://www.gm-trucks.com/forums/index.php?/topic/199229-HUD-in-Silverado/Sierra
Sent from my SM-G935V using Tapatalk
Sorry if this is an ignorant question but how do you switch between the 3 different modes on the Denali instrument cluster? I can't seem to find it in the owners manual. Which mode do you like the most?
Tahoe14
Central Fl
jpcortese, page 155, also for quick reference look at the index in the back of the manual.
C
cmatt
I wanted to update you guys. My windshield got a rock chip that ran across it. I was able to get the glass shop to order an HUD spec windshield for replacement. The ghosting is gone. The display is much clearer now. Pics don’t do it justice.
Here was a before shot
Tiki
@cmatt your my hero lol. While researching Cluster swap information I came across this. Excellent information as usual.
C
cmatt
Lol, thanks man. I try!
kielyr
