Denali conversion kits?
tv559
Madera, CA
Where can I find them at? I have an 02 Yukon and Im looking for a denali front end.
Thanks,
tast101
Colton, CA
Probably could hit up a junkyard and maybe get it cheaper. Here a Esky kit for example, http://www.fbirides.com/product.asp?idno=8680, is about $2400 plus s/h.
Denali front end conversion parts
15046662 - Filler between grill and bumper - LH
15046666 - Filler between grill and bumper - RH
15199554- Parking lamp – LH
15199555 - Parking lamp – RH
19130789 - GMC Denali Grill superceded
15218077 - Headlight – LH
15218078 - Headlight – RH
12479754 - Bumper cover
14093088 - Retainers (7 needed)
15149708 - Retainers (12 needed)
15153490 - Insert
15060470 - Impact bar
16531085 - Fog lamp Assembly – LH
16531086 - Fog lamp Assembly – RH
15059859 - License plate bracket
88937235 – bumper filler
15706323 - emblem
88944418 – Fender right
88944417 – fender left
12477699 - Hood
bmtxl
I actually wanted to do something like this to give my '02 a facelift. What can folks recommend as an alternative to make the front end (or whole body) look better? I'm not interested in lowering it as I don't want to change the ride, but would like specifics as to body panels, bumper covers, lower spoiler, etc. manufacturers that won't break the bank like doing the above Denali makeover... nothing too crazy, subtly bad ass..
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Would do you have a yuKON?
Gzes
the drifting 2dr
Wichita tx
thats nothin for my obs i found a silverado conversion like 03 ish for 3500 up. i said hell no! and just put in a new grille, halos, and basically redid the front for under 300:)
bmtxl
@01tahoenjn, 02 Yukon XL, white ext, tan int, stock.
bmtxl
@ OP et. al., If I were to do it in stages, can I get away with not doing the headlights and turn signals? Will a Denali bumper cover just fit over the stock bumper? What's the minimum required parts to do the grille down to start and then come back for the lights?
01HDtahoeNJN
North Jerz, NJ
Nope all or nothing... What I would do like mentioned before is slowly but surely get all parts need through junk yards and look online as well I'm doing a Tahoe-HD silverado fronted swap for under 500... It's less parts needed than a yuk to nali but I save a ton by waiting and overtime amounting parts good luck!!
Saucy_Walnuts
