Denali Shaking 70+ mph
noob
New Orleans
Lost wheel weight or bent rim? Sometimes the bend on the inside so it's not as noticeable
InTruckDesign
SW CT,
steering wheel shake 90% of the time is tires that are out of balance, As tires wear they also go out of balance, a new tire with 100% tread is going to balance way different than a tire that is only at 30% tread.
CYKBC
It's good practice to balance as necessary every tire rotation.
edgaranah1
Corona California
Steering wheel shake its mostly the front tires. If you feel it in the seat then it's your rears. But u should get all four of them balanced.
Sent from my iPhone 4g using Tapatalk
stapleto
Michigan
Could it be front wheel hub wearing out? How can you check lateral hub movement?
h0m3w3CkeR
