Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Are your buttons stuck a little? Mine did that when I first put it in? Try disconnecting for awhile and it might reset, ust a suggestion, but may work.
07, seroiusly u have an addiction to this site. every time i post or read a new post **** there u are replying to it hahaha are you one of them there "geeks"?
I had the same problem, invisible mold is shorting out the printed circuit on the back of the cluster. Take it out remove the back cover, brush the board with a stiff brush or toothbrush...fixed easy. I didn't beleve it until I did it myself.
I've been running for two weeks and over 1100 miles since brushing the mold off with no faults or foregin languages. That was a pain, the fix was simple
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
