dieing battery is realy starting to aggravate me any advice
bluegoose95401
hi all i have a 03 Tahoe Z71 its pretty well optioned, factory DVD player in the back jvc touch screen DVD player/ stereo in the front. the issue is my battery keeps going dead. its intermittent some times its over night sometimes its 3 days but it always dies i put a new battery and alternator in to it and took out the jvc to check for bare wires touching ground and nothing. im at my wits end with this does any one have any advice of where to look i really need to fix this issue and pronto thanks in advance
02tahoeindiana
My truck had the same problem last fall, ended up using a voltmeter to check every electrical item on the truck. Could not find the parasitic draw. Eventually it stopped dying and now will if i leave it sit for more than a week locked. If the truck is unlocked there is no problem, if you have the change let it sit unlocked for 3 days then see if it dies, if so you could disable the security system.
PwtrSS_OakCliff
Dallas, TX
Was your battery dead when you replaced the alternator? Did you get a jump from another car? If you answered yes to any of these, you need to get a battery charger and let it charge over night. Just because the alternator is charging does not mean the battery get to get fully charged. I had this problem when I did my alternator swap. Charged battery and problem gone.
tsb09000
Thread Killer
I had a similar problem and all it turned out to be was a stripped battery terminal (I had a screw in side post at the time) Switched posts and everything has been fine since.
B
bluegoose95401
You will have to use a voltmeter and look to see where your drain is coming from.
http://tahoeyukonforum.com/forum/showthread.php?t=46299
so i followed this post and pulled all the fuses and relays it has 1.32 amps of draw when i take out the starter relay all the draw goes away when i replace it it all comes back any ideas
---------- Post added at 07:05 PM ---------- Previous post was at 05:15 PM ----------
i think i fixed it by playing with the relay a little more so lets cross our fingers and c what happens
mikewayne
In today's vehicles electronics plays an important part, and there are many parts that drive there power from the batteries and sometimes to keep on doing so even when they are idle and may lead to quick battery drain.
B
bluegoose95401
so the battery i still dieing over night today it happened with in a few hours i cut both sides of the red and black rubber cover the one covers the terminal connections to insure that it was making proper contact went back ad checked for draw it started as 1.32 but with in 45 seconds dropped to 0 so there no draw new battery new alternator new belt is there something here im missing that should be all there is right
---------- Post added at 06:15 PM ---------- Previous post was at 05:24 PM ----------
alternator is putting out 14.25v when its run for a wile then turned off the battery reads 1265 then drops down from there when it hits 12.20 area it slows down but continues to drop when it his 12.20 its been 35 min and now it dropped down to 12.10 will check again when i get off work around 6pm to see if it has continued to drop what is the normal battery voltage when parked for these trucks
wormrawlings
