Differential (Boom)
00Tahoez71
Anyone ever explode a carrier? I thought I chewed up the spider gears, but when I opened the cover, big chucks of iron dropped out. Can the bolt from the pin cause that, if it backed itself out?
Thanks,
Corey
Scottydoggs
NJ
last rear i killed ate its self, the bottom of the rear was full of metal chunks, 1/2 the gears were sheared off the ring and pinion. im talking handfuls of metal, and i got large hands lol
while you are in there now just replace it with a Eaton Detroit, then all you may experience is some worn bearings sometime down the road, cost's a little more but it pays off in the long run.
Don't those like to oversteer if you're accelerating in a turn though?
I have never had problem, I just know I broke 2 factory g80's and then a different one I don't remember the name it was a $400 unit halfway decent but it broke too, put in the Detroit it didn't break but after 2 years I did wear the bearing's down, I was pretty severe on the NBS
HAIGDEDNEDNA912
