Dipstick seal
tyrone27
How hard is it to replace the Dipstick seal? It's leaking fluid bad.
Sent from my SM-N920P using Tapatalk
willxfs
I think it's just RTV and not an o-ring. Should be very simple. Remove a couple bolts that hold the bracket, remove the dipstick and bracket, clean the surfaces, dab some RTV on the dipstick tube that inserts into the block and replace. Good luck.
T
tyrone27
Ok thanks. I brought the rubber gourmet that goes into the transmission so I'm doing both.
Sent from my SM-N910T using Tapatalk
Njoppy
