Yesterday I was on the highway with my 2007 Tahoe LTZ. The Cruise was set and all was great. I thought I could hear some window noise like one of the windows were down, but I did not know which one, so I pulled up on all of the switches, and then I started to slow down...
Puzzled, I looked at my IP and sure enough the Cruise light was not illuminated, so I hit resume and went on my way. I started thinking, "what caused my cruise to turn off?" I did not hit the brake or the Cancel button on the Steering wheel. So I started to play around again to see what I did.
As it turns out, if the windows are all the way up, and I pull up on any TWO switches the cruise will cancel. It does not seem to matter if it was the front windows, the back windows, the two right windows, etc. One window would not do it, but two at the same time will, every time. It is very repeatable, did it on the way into work this morning just to see, did not matter what speed I was at, 40mph, 70mph.
Anyone else ever experience this? It is not huge, but a bit concerning honestly as I ask myself if it is a precursor to something else coming down the pike.
The only possibilities that I can think of is
1) There was a power drop when I pulled up two windows at the same time, causing my cruise to cancel. But the IP lights did not appear to dim.
2) The windows use the data-line like everything else in the car, and the act of pulling up on two windows at the same time is the same signal as the cruise signal. This would ring true, but the cruise does not cancel If I roll two windows up at the same time when they are down.
John
John
