*** Disclaimer: Try at your own risk. I have provided some information and a method. Please be aware that you can break your vehicle. I am not responsible for what YOU do to your vehicle. That said, good luck modding. ***
Quick and painless. Takes 2 tools and about 20 minutes.
Tools:
5/16” Nut Driver
Pick
Procedure:
Drivers side
1. Unplug the 8 wire connector (only 7 present) from the headlight.
2. Strip back the tape and wire loom protector about 3”
3. Using a small pick, gently remove the off-white pin separator from the connector (see picture below)
4. Gently using pick, unlatch the detent for #2 wire (yellow). Gently pull the yellow wire out bottom of the connection. Bottom of connector has numbers to indicate which wire is which.
5. Gently using pick, unlatch the detent for #6 wire (purple). Gently pull the purple wire out bottom of the connection. Bottom of connector has numbers to indicate which wire is which.
5a. #7 wire will be the same purple (grey on passenger) color. Do not remove this one.
6. Feed the purple wire into the #2 spot. Align the male end to match the other pins.
7. Feed the yellow wire into the #6 spot. Align the male end to match the other pins.
8. Ensure all of the pins are aligned. #8 will be empty. Gently insert the off-white pin separator into the connector. It will click into place and sit flush.
9. Put the wire loom cover back in place and put a few wraps of electrical tape as needed. Reconnect connector to the headlight.
Passenger side
10. Using Nut driver, remove the hose clamp from air box hose to intake silencer. Remove the MAF harness. In-clip the MAF wire harness from lower ledge of the air box (by cylinder #1
11. Remove the air box. It will come out without having to take lid off.
12. Rinse and repeat for Passenger side. The #6 wire will be gray. Exact same placements as drivers side will be utilized.
13. Re-install airbox and MAF harness.
Enjoy. With headlight switch in Auto. Now whenever DRL are needed, the LED strip will turn on. And when headlights are needed, the low beam and LED strip will turn on.
See post #2 for wiring schematics and the how/why this works. Of note: whenever the running lamps are on manually, you will now have the headlights on as well.
TLDR version: swaps the low beam and the DRL circuits. LTZ uses programming to do this in PCM
Tools:
5/16” Nut Driver
Pick
Procedure:
Drivers side
Passenger side
