foxracer025
- Joined
- Dec 29, 2013
- Posts
- 88
- Reaction score
- 0
Nice write up. I have a 2004 Tahoe Z71 4x4 that I just changed the rear brakes on. I can confirm that you will need a 16mm open end wrench and a 12mm socket to remove the outer piece of the caliper, and a 18mm socket to remove the caliper bolts. My best advice if you are doing this is to take a set of the old brake pads with you to the auto parts if you go. I went to the auto parts and got the best ceramic pads they had and they weren't the right ones. Had to make a trip back and the guy had to open 5 different boxes to find the right ones. Other than that great write up! Thanks.
