DJM RK2000 and pinion angle
03TahoeZ71
Minnesota
I'm getting a vibration from the rear of my Tahoe. I just put in Belltech spindles and pulled out the 1" spacer from my rear springs. It only seems to vibrate when I have the 1" spacer removed. I think its bad pinion angle that is causing it.
Would the DJM RK2000 hardware kit help with pinion angle?
This is on a 03 Tahoe Z71.
The setup:
Belltech Spindles and keys up front.
Beltech 3"-4" springs w/spacer out in back.
Belltech Street shocks all the way around.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
The setup:
yes plus push the axle back into the well farther to center it more. also will fix swaybar horrible angle in rear.
trav02nj
