Do I need to do anything with this battery current sensor?
Fless
Super Moderator
Elev 5,280
I just have the mx plus adapter for scanner bluetooth is there any way that tell me witch version in pcm ?
Sent from my LGL722DL using Tapatalk
I don't think so, but I'm not certain, either. I'm going to be trying some of this Tech 2 programming once I get off my butt and spend some quality time with it.
Woodblocker55
I could buy extra PCM for $159.99 how many nightmares would that cause. He says latest updates. [emoji849][emoji15]88586996e849d8cf5a69f5974f3db1d5.jpg
Fless
Super Moderator
Elev 5,280
See if he programs it to your VIN; otherwise you'll have to add that to the cost locally. It says "programmed" but best to be sure.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Check to be sure and check for reviews on this seller. Almost sounds too good to be true. Only $60 more for a updated PCM than going to the dealer and is supposed to be plug and play, Right?
Woodblocker55
Yes I know abit scared to try it ... He's probably taking junkyard ones and just flashing them. Pretty scary ..hmmm
Local GM said flash was under $100 so I go that way for now .
Woodblocker55
2006 gmc yukon xl slt option 2 185,000 miles GM garage flash PCM What could go wrong if they flash it . Does it bring on any more issues then are already there ?
Woodblocker55
PCM look up what was changed in PCM computer updates since 2006 ? Or is that top secret GM information.??
2006 gmc yukon xl slt option 2.
Woodblocker55
I was on the tis2web to see what was updated in pcm there is a bunch of up dates .
When they flash it at GM garage will everything be updated . Because of issues they point out I have that issue .. even the sometime cd won't load in changer . It all indication it was never updated even the 3 mph to fast on speedo was in there and mine reports fast just like that . And that the throttle body issue . Fuel delivery system recalibration is what said in there also .
if you take it in just be sure to specifically request all available updates, one update or all updates will be the same price it takes like 2 minutes to do each update, some may take 10 minutes but that would be like stuff for the security system.
Woodblocker55
So I should say all available updates. Long as I'm paying for it . Then as I work on it I will always know lastest updates are in there . No more take it back again . Right ?
I have appointment all set to take it in.
joakleyTYF
