Do the 2005 tahoe have 3 acutators in the front?
Monewill2003
Maryland
I know there is one on the passengers side floor and maybe one on the drivers side. How are are the other two to change not trying to break the bank chevy dealer told me 1990.00 to change them all and solder a wire clip. they changed the clip for me but I told them to hold off on the work cause they were trying to kill me for there labor! Does anyone have a video of changing the drivers side and the other one that is not the passengers side
NathanJax
Vacation Nathan
Administrator
Jax, Fl
There is 3.
1 for pass side heat/cool
1 for drivers side heat/cool
1 for positioning from the feat to the hands to the defroster
I forget exactly which one is which, but I think the drivers side is underneath the dash on the middle/pass side. The passenger one is on top of the dash behind the radio (have to take the top of the dash out) and I'm not sure about the 3rd one.
Monewill2003
Monewill2003
Maryland
That was a big help thanks. cause my drivers side is blowing cold when I got the heat on. that's the one down on the floor by the passengers side. A BIG THANKS to you I want to change all three just because I think to make sure everything is working right.
treehan77
TYF Fiend
Crestview, FL
well the dealer replaced the one by the middle hump in mine before i got it and it malfunctioned less than 5000 miles later. i actually just took it out and put it back in and its worked since. so i would think twice about replacing them just because.
TheKid_eric
Camp Lejeune
the one under the driver side on the right at the top is the positioning one. if you are going to replace it do not take the track that the actuator is on off or you will spend a good hour or two positioning it back into the right position.
Josejr00
