Do these codes point to a bad TCCM?
TTro33
C0283 Traction Switch shorted to ground
B0790 Transfer case Neutral indicator shorted to ground
B2725 ATC mode switch circuit malfunction
I replaced the front hubs trying to get rid of the ABS Traction Control stability lights. I went to autozone to get these codes and they let me reset them all.
In the parking lot to my amazement, I was able to put my AWD 2005 Tahoe into 4 low and it worked and turned off the traction control and all the lights were off. It didn't last long everything went back to normal when i started moving.
I left out the front ABS sensor codes because I replaced the whell bearing with ones with new sensors. There was a code for the right rear Abs sensor, I think that is what made it all come back.
It seems like I am close to solving all the bugs now, just a new rear ABS Sensor, and hopefully a TCCM and all will be well.
Roscoe2352
