DennisT
- Joined
- Jul 25, 2016
- Posts
- 103
- Reaction score
- 37
A couple of days ago the GPS and radio display and controls on my 2016 Denali would not come on when I started the truck. It was a blank screen and nothing related to it would work. A while later I started up and everything worked as usual. Then the next day I get a low tire pressure warning with all 4 tires at 30 psi. Now I run my tires at 30 psi because I like a softer ride and with the huge tires I just don't see a need for higher pressures. I never received the warning before and the center display showed all 4 tires and alternately highlighted each tire pressure. My question is could my system have been going through some type of firmware update from GM through the OnStar system which changed the tire pressure monitor parameters and could explain the system behavior.
Dennis
Dennis
