Dome Lights
J Farris
For some reason the dome lights wont turn off I have to take out the fuse. I tried a new BCM and light switch but nothing has worked, none of the doors are open so im stuck at this point.
J Farris
J Farris
Might check the door switches to make sure one isn’t shorted out.
The left trunk door has a female connector but no male I dont know if it’s supposed to be like that or not
wjburken
Eastern Iowa
What make/model/year do you have? I assume from your last post you have barn doors instead of a liftgate.
J Farris
J Farris
Silly question', but I've done this more than once. Is the rotary dimmer in the "on" position?
It’s in the correct position and the dimmer isnt pushed up
tmborske
