donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,682
- Reaction score
- 2,961
My 07 6.2 Denali with L92 didn't have AFM but It needed this TSB and a lot more.Don, thanks for the great info on the oil burning fixes for these engines. The TSB is referring to the AFM engines I don't believe that my 08 has according my research, and it doesn't switch over to 4 cylinder mode liked my 2013 5.3 does when I drive it. I see all your plugs looked like my one "dead" one, amazing it even ran.
Do I still need to change the valve cover if I don't have AFM?
Should I still desludge or "decarbon" with Gunk Motor Medic my engine?
Thanks
Mike
I did the deflector($7), oil pickup o-ring($5), 2 day long cylinder soak w/Motor Medic($5), cleaned the spark plugs and put them back in. They are still in the engine 30+k miles later. The Motor Medic freed up the rings and cleaned the carbon out of the cylinders.
Without the improved valve cover it would keep sucking oil into the intake, into the cylinders, sticking the rings again, and leaving carbon deposits everywhere.
I also changed the engine rear main seal, oil pan gasket, new torque converter, external tranny gaskets/orings while I was at it.
2 yrs and 32+k miles later it is still dry as a bone, doesn't consume any oil, and the catch can I installed doesn't catch any measurable amount of oil.
Here's a couple of more threads I did 2 yrs ago when doing all this work:
https://www.tahoeyukonforum.com/threads/rear-main-seal-job-pan-etc-07-yukon-denali-6-2.108334/
https://www.tahoeyukonforum.com/posts/1437459/
