Door handle replacement "how to" info
992dr
Eastern N.C.
Is there a "how to" for replacing the exterior door handles?
Mine is now starting to fail, not every time but more often than not. Actually it may be time for both drivers and passenger exterior handles.
What is involved with this?
Any info would be much appreciated.
Thanks
992dr
992dr
Eastern N.C.
Must b a seasonal thing... My door handle went cuhput today to... Thanx for the info fellas...
Hah, mine went about two hours ago. Almost ripped the f*%#r off. My passenger side is on its way to. May do them both at the same time.
Thanks for the links guys, I appreciate it.
bowtiefreak
No Quarter
Near Philly
It takes a while just because it's hard to get at. Little hands helps. But it's a one man job and took me 2.5 hours I think....in the rain.
992dr
992dr
Eastern N.C.
2.5 hrs. Thats not too bad, I guess. Little hands, I may have to tag on an extra 30 minutes then, cant say I have the smallest hands, hah.
Does anyone have any info on how to get the door panels off?
Just curious. What breaks or gives in the door to cause this problem? And, is it the exterior handle that does this or the internal components?
What exactly do I need in parts?
Thanks again
992dr
992dr
Eastern N.C.
So, what did you guys use to hold the interior handle on? Rivet or self tapping screw?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Pop rivet. Gm sells the exact one for $2 a piece. If I remember correctly the typical hand riveted may not have a big enough nose on it. Need a bigger two hand riveter.
Stevemo70
