door lock diagram for 2 door.
yukonaetahoe
Oakland, CA
does anyone know the diagram for the 2 door tahoe or yukons?
ive had this door lock problem for 3 or 4 months and cant figure it out im just gonna replace the actuator this weekend and pray to the gods above it works. i just dont understand why they both dont work. grey aluminum fuses seem good replaced with 4 new ones and nothing changes.
im not technician and i dont know much of what im doing but i am trying. if n when i find out i will let you all know how it was fixed incase somsone needs it.
also to remove the lock actuator im assuming we have to remove the wall which is sealing the window, but do i someohow take out the window firsat or wat the heck should i do?
i wish there was a master manual somwere out there especific for hese suv's id pay anything
dwmmatt23
central valley cali
whats your problem? im also having a problem, both my switches dont work, the rear hatch button doesnt work and the center cig lighter doesnt have power to it. i think they might all be related and my fuses are good as well. keep us posted
yukonaetahoe
yukonaetahoe
Oakland, CA
Here, give this a go and see if solves your problem.
http://69.60.238.10/ira/DoorLocks.pdf
I know this one is for a 4-door, but I couldn't find one for a 2-door.
yeah but for a 99...... mine is 95.
ive seen on ebay they sell shop manuals does anyone think there worth the 130? or are they a rip off?
---------- Post added at 01:50 PM ---------- Previous post was at 01:47 PM ----------
door locks wont open or close with my keyless remote or if i manually presss the button on the door...i took my switch of the driver door and put it in a 96 sierra and it worked fine so doubt its switch. someone said change the actuator and what i did was plug in a new one and right away it locked the doors pressed it couple times and did work, but what i did notice was whne i pressed unlock while it worked as soon as it unlocked, it locked right back up. im hopin theres a relay under the dash somewere hidden but ofcours the retarted ass haynes manual dont help for shit.
clean454
see my door lock unlock buttons don't work and the cig lighter doesn't work
but my key less works and the fuse is bad when i replace it it pops instantly... so idk either ive done some search n around and haven't found anything
yukonaetahoe
yukonaetahoe
Oakland, CA
i believe there is a door lock relay under the dash somewere and i will behind to take things apart today! i checked autozone online and somehow it shows and actuall door lock relay but it wont give me where it is located nor the books or even online. but im not giving up...... the switch is goood and i checked 3 different door actuator and none work, as well as swaping the fuse about 15 times sooooooooooooo unless anyone else know anything i dont hopefully next week ill have some great news for you guys and any future problem havers.....
dwmmatt23
central valley cali
im right there with you, except my fuse is good
yukonaetahoe
yukonaetahoe
Oakland, CA
jvelderman
