door lock diagram for 2 door.
yukonaetahoe
yukonaetahoe
Oakland, CA
2 door/ door lock relays are above the brake and gas pedals if you go to (www.the12volt.com) they have alot of good info on our trucks for wiring
YEAH I FOUND IT!!!!! thanks!!! but yeah i had already found it, now i just gotta buy the new one and see if it works lol that might take another week.... cash flow is slow.
dwmmatt23
central valley cali
i wonder if they would have these at kragen or autozone, might be worth me trying. if you get it done first let me know if it fixes
yukonaetahoe
yukonaetahoe
Oakland, CA
so i got one from the junk yard and put it in but same crap. no movement of the door locks. just a stupid click sound from the relay and the switch. i guess my only shot is following every single cable and find where the fault is.
and i did see you can order the relays on autozone but have not checked in the store. but i beleive classictrucks.com has it for sale at about 34.99
TORONTO 95 GT
I had something similar happen and all I did to fix it was lube everything and make sure it was free. I took the door panels off and cleaned all contact points and pivot points, lubed and operated all by hand until moving very free. I then liberaly applied anti sieze.
No more problem and I did not replace a part.
Do not put in a heavier relay fuse or anything. It worked before fix the problem not the symptom.
jvelderman
