Downstream O2 sensor diagnostic
Fless
Super Moderator
Elev 5,280
You can also load test the heater circuits with the right test bulb(s). Eric O at South Main Auto YouTube shows that in some of his videos. I need to make up a couple of test jigs like he has.
Even with the downstream O2's tuned out, your Cat monitor passes?
I wonder how that works?
Well.....it's tuned out. I haven't actually been to an inspection. All they do is plug into your obd and do a cat visual. No cats and a cat--you pass.
W
wsteele
Here in ID, they usually only do the plug in ODB. I have had them walk around with the mirror checking to actually see the cats in place, but not every time, seems random.
The reason I asked about the Cat monitor is that is one that has to show “passed”. The only monitor we can have that is not completed and still pass the test is evap.
I don’t know squat about EFI tuning, I didn’t realize they could tune out (or at least make happy), the Catalyst monitor without the downstream O2 sensor there.
kbuskill
NE. FL.
I just remembered seeing a section in the Tech 2 when I was playing with it yesterday for the O2 sensors heater circuits.
I didn't go into that menu, as I had no need to, but I think it was in special functions so it is probably some kind of test.
You may want to check it out. You might not even have to slide under the truck if you cam test them from the driver's seat.
Fless
Super Moderator
Elev 5,280
I posted this in a different thread but it might belong better here.
This article might shed some light on what to expect.
https://www.aa1car.com/library/o2sensor.htm
What I've been reading is that, generally, the mv reading should move around between 100 mv (lean) and 900 mv (rich), but the desired value is around 450 mv. Obviously the sensors are always changing, which is the point of their function.
If you're seeing consistent values lower than 100 mv, I would think that the sensor might be somewhat out of range (weak?) or there might be a problem on that bank. It might be worthwhile to swap the two that are in their respective positions to see if the pattern follows.
W
wsteele
Thanks for the article, pretty thorough explanation. I didn’t know about the breathing through the wire ports. I wanted to do some reroute of the wiring after I finished replacing the O2 sensors recently, mainly because I didn’t like how hard it was to get to a couple of the connectors. I think while I am there, I will make sure each set of wires coming out of a sensor, go downward to assure water doesn’t run down into the port.
W
wsteele
I found an article that called out a #7740 Incandescent bulb as the right wattage (22W) to simulate the heater circuit. If I can't diagnose the heater circuits with the Tech 2, I will slide under and check the resistance on the sensor heater lines (my old sensors show 11.7 ohms). If that all checks out in the green, then I will go and find the bulb and socket and make up a test fixture for the heater circuits. I hate the idea of having to find a fault in the O2 heater wiring... :(
W
wsteele
As @kbuskill suggested, I spent some time with the Tech 2 and the O2 sensors this morning and the heat circuits seem to be working as designed, all four heater circuits reported a similar amperage draw.
My conclusion is that as @Tonyrodz suggested at first, one sensor must just be a little slow. After getting up to full temp and running the engine above idle in cycles, both number 2 sensors are reporting very similar voltages and track throttle applications.
I may swap in one of the old downstream sensors into Bank 2 position and see if it responds a little more quickly during the warmup cycle, although it appears the new unit works fine after the engine gets warm and is in driving mode. This last bit will be just for my own edification.
Aaron morrow
