Dreaded Effing lifter tap...... - SOLVED
Blackcar
No. When the lifter is collapsed the distance the pushrod travels is less, there will be no valve to piston contact.
I did a lot of research when my lifter collapsed.
It is the geometry of the pushrods and placement of rocker arms above the valves. They do no push strait up and down like an old small block but instead have a pronounced angle that works 'fine' until a lifer collapses. The gap created from the collapsed lifter causes the pushrod to bend in very short order.
A view on valve train.
B
B-train
Well, update as of 10/19. Got the truck back and it runs as good as new. In going over the situation with my dad (master mechanic) he basically said it was most likely cause by a heavy right foot. In thinking back on the situation, my foot was heavy immediately after the situation, getting irrate at a stupid Jay walker and trying to get out of traffic. A floated valve can do the same thing.......so, it may not have happened right then, but driving several hundred miles on a fatigued pushrod could have showed up later. Or....a ******* porter kid drove it hard at the shop.
All speculation at this point, but it makes sense to me. $650 later for diagnosis, repair, and oil change and we're back running. Drives like new!
We'll give it some time and see. All emotions have settled down by now, cooler heads have prevailed, and no rash money dumping situations have happened. What it has shown is that we were used to having a spare yukon available for the 'what if' situations due to me having a company truck all these years. Now, the 'spare' is a DD. We'll probably solve then issue with a good used, mostly depreciated, rust free 3rd vehicle to use as needed - also something that gets much better mpg for all the bee-bopping that goes on in my household.
At this point, it's nice to have it back in the fleet. I'll keep the thread updated if something else changes.
Thanks to all the insights and replies!
Sounds like you are good to go. Confidence/trust can be a fleeting concept with vehicles. You trust it until you don't, and it can take a bit of time to regain trust, once lost.
Seamus
Palm Beach
I am at 89K and our 6.2 runs like a sewing machine. It was a well cared for rig w/ service records before us and I am a fanatic with maintenance and care. I am under no illusion that the lifter will not fail at some point. We plan on having this truck for many more years. So my plan is buying the parts for the delete slowly as the budget allows now. I already sent the computer out to delete the AFM. Buying the stock cam for the delete w/ LS7 lifters. Then when I am ready at my convenience i'll plan out having the job done. I will also travel with these hard to find parts sometimes in the truck. Hardest part is having the delete parts and computer already done. Then if i am out of state any dealer or independant shop can bang this out if need be. For me this relieves any anxiety about reliability or being stranded. All good shops have done many of these cam jobs. Thats why getting some of these parts can be a problem. Primarily the fuel injector pipe, and cam bolt. Good luck
Geotrash
Dave
Richmond, VA
THIS is a really nice example of an effective risk mitigation strategy for one of these rigs. Love it!
05_200Ktahoe
