Driver Bottom Leather Seat Cover and Pad Install
Bill D
Just reviewed the videos on You tube and see there is no way out of removing the seat to replace the Leather cover and seat foam on the drivers side. Very reasonable on ebay for a number of sellers. Pad, cover and socket and next weekend out it comes, in with the new!
Derick
Indy Suburbs
Following....need this as well on my burb. 350 in parts alone, or I can take it to my trim shop and they will do it all for 350....no brainer. But if this ends up being decent quality, and by chance; cheaper.....then I'm in.
Just make sure if you have leather--you get leather as the replacement, and not vinyl. It's not very difficult to do, but a pita if you've never done it before.
Bill D
Bill D
The seller has great reviews and claim the covers are leather and Made in Texas. They look like factory. I did covers to put heated seats on my wifes 03 Avalanche and I know they can be a pain. These covers are the push to connect in place so they look much easier than the old hog ring attach style . Pulling the seat out in the PITA part, but the video walks through step by step.
Bill D
Bill D
I actually think the 100$ extra to have someone else do it sounds like a good deal. You could gain back a Saturday afternoon to do something more fun! A little less than $250 in parts this way.
I never knew they had that push in/clip setup. I had to repair a seam in a seat and needed to take it 1/2 apart--cutting the hog rings and peeling it back. I replaced the hog rings with zip ties. Works just as good. Can't even tell.
Bill D
Bill D
Just received them today, now the nasty part - pulling the seat!
jsoltren
Funny, I bought from a shop that claimed the same things, and then I found my two tone seat covers were half real leather and half fake leather. I called them and they said "that color was discontinued by GM so we had to make a substitution". I was furious - and already out $500 for covers and installation - so I left it in there.
A leather guy showed me a trick. Press a finger into a seat cushion. If it's real leather you'll see creases radiating outward from your finger. If it's not, you won't. Check before installing!
If it were me, and I were doing it again, I'd do it myself, give it plenty of time, and take the opportunity to check everything in the seat. Lube all the tracks and hinges, check all cable tensions, fix any broken plastics, replace any cushions. The way I see it, if you're at the point of doing the cushion, everything else is far gone too, and you'll thank yourself later.
Mreedini
