driver-side front window acting up
dsltrc
Virginia Beach, VA
i have noticed in the mornings at 6am on the way to work that when i roll the window down for any reason that it doesn't want to come back up... i'll drive a bit and try it again ans it seems to start working again....but in the afternoons it seems to work just fine, as if its the cold making it act up... well this morning it seemed to get worse, i rolled it down at the mailbox and it wouldn't go back up so i drove abit and tried it again, started going up and then it stopped, i went thru this process almost 6 times before i got it all the way up... the 3 other windows work fine during all of this process, does anybody have any ideas, i guess it could be the switch acting up or the motor going bad... i just havn't dug into it yet... thought i could get some good ideas as of where to start
Jaycenk
Florida
Could be the motor or the regulator. I would pull the door panel off and start testing it and see if the regulator is jamming up or if the motor is just weak.
Dremar79
