Drivers door door pop, how to fix?
r33pwrd
Sammamish WA
Well title says it all.. I have greased the small wheel and it helps for a few weeks but I am tired of doing that and its only getting worse. It appears the wheel does not turn than "slides" causing the sound.
I can find lots of hinge rebuild kits but nothing that shows that wheel being replaced without going OEM (major pain in the butt I would think)
Any ideas? Thank you
2007 Yukon Denali
jasonconway5
2007 Yukon Denali
several posts on this within the past 2 weeks. 1 of which was mine. The part you are looking for is called a door check strap. 30 on ebay, 50 at parts stores
R
r33pwrd
Sammamish WA
I did look around on here but did not see anything... so many sections I was not sure what one to even look in.
FYI my 2007 does NOT have a strap...
jasonconway5
again, DOOR CHECK STRAP. go to advanced auto parts, doorman, auto zone, dealer. all have the same name for it.
Buddha76
