Driving in L9 and DFM
Garth Knight
Yeah, in regards to the 6.2L, does driving in L9/disabling DFM increase or decrease the likelihood of lifter failure? Anyone know?
JasonHTX
Looks like they'll never be a Range or Pulsar LT device for our rigs. Bummer.
jimgeb
Is there is any evidence to indicate that disabling DFM electronically will prevent lifter failure, since the collapsible lifters still remain?
Micahsd
I have my doubts driving in L9 would be the perfect solution as when in Park the DFM will probably kick in while idling...if that's the case, then the issue is still going to crop up. That's just my take on it.
I've had one side replaced at 9,100...currently at 11,500 and a little leery as to when the other side will decide to go.
julio62
I know I’m going to regret asking, but what is L9?
L9 or M9 is when you shift out of "auto" and put it in a gear manually. L9 would cover all the gears below that for shifting, that is it will shift automatically through gears 1-9. If you put it in L6 or M6 for instance, it will shift through gears 1-6.
2025 Yukons like mine have steering wheel mounted paddle shifters making going up and down quite easy.
olyelr
Elk Rapids, MI
AND, when u put it in that it disables the dfm from kicking in…
murdrmunkee
Well I am glad to hear that, I will be driving in L9 almost always from now on.
My Denali was built on May 18th outside of the dates specified for the lifter failure but unfortunately I don’t have to much confidence in that timeline.
I love this rig but the reason I purchased this as my retirement vehicle was to travel the country and being left stranded a few thousand miles from home is not very appealing.
Hi, which dates have been identified for lifter failure? how do i check if my car falls on that date?
Thank you!
RG23RST
Thank you!
September 1, 2020 to March 31, 2021. Contact any dealer and provide your VIN and they can tell you if any were replaced. Initially we were only replacing one side (which IMO was dumb) then after some time all 16 were instructed to be replaced. If yours got out before the stop-sale it's worth checking on.
olyelr
Elk Rapids, MI
Pretty sure ive read about much newer model years than that blowing up. But i dont keep up on it.
Gabby3983
