JonnyTahoe
OK Thanks for the info.
Yes. If your headlights are on in the daytime and your DRLs aren’t, that is probably the issue.OK Thanks for the info. That's that little dome thing in the middle of the dash near the windshield ?
Ordered and installed another Light Sensor made no diff still have headlights coming on all the time.the drl running lights have nothing to do with the headlights, if your headlights are coming on in the day then you might have a bad sun sensor or it became disconnected or something.
Then it sounds like the problem is not the sensor it's self there may be a break in the harness somewhere, if you have a tech2 it can help you troubleshoot the problem, I would check the sensor harness and see if it is getting power, not sure what the voltage should be to the sensor it could be anything from 5v to 12v typically. the sensor is just a light activated microswitch so it probably runs on 5v (just guessing) is there anything else not working? could be on the same circuit, have you checked ALL of your fuses? only takes a minute with a meterOrdered and installed another Light Sensor made no diff still have headlights coming on all the time.
Actually yes I was getting the Low Wiper Fluid message so ordered a new GM fluid level sensor removed entire fluid bottle. even with fluid bottle removed the new sensor seal actually made it harder to install. Still getting the message every day. Have not checked any fuses but will now Thanks.Then it sounds like the problem is not the sensor it's self there may be a break in the harness somewhere, if you have a tech2 it can help you troubleshoot the problem, I would check the sensor harness and see if it is getting power, not sure what the voltage should be to the sensor it could be anything from 5v to 12v typically. the sensor is just a light activated microswitch so it probably runs on 5v (just guessing) is there anything else not working? could be on the same circuit, have you checked ALL of your fuses? only takes a minute with a meter
